Tab control resizes unexpectedly
I'm facing an unexpected issue that  I cannot solve.
In my project I have a tab control that fits the whole screen (it runs maximized). It contains two tabs.
Here is a screenshot of the top left corner:
As you can see, the tab control fits nicely close to the edge of the screen.
At some point in the code, I resize the scale, max and min of a silver Gauge using the following:
Here is a screenshot of the gauge:
When it is resized, the width/height of the tab control changes for an unknown reason. See below the same top left corner:
As you can see it moved left, the word "Bluetooth" is gone!
Nothing else seems to have changed in the GUI.
I used the "Bounds" property node of the tab control and realized there was a change in width. There is also in change in the position of the tab control. However, bounds is read only and I cannot programmatically resize the tab control.
My questions would be:
1- why is the silver gauge modifying the whole frame?
2- More importantly: how can I prevent the gauge from changing the size of the tab control? Is there a way to lock all the dimensional properties of the tab control?
Alex
(4,947 Views)
Accepted by topic author shinagan2
What I would find to be most unexpected is the Tab control behaving itself.  I would try turning off Auto Grow (right-click > Advanced) and see if that helps, or try using the System Tab instead and hoping for the best.
(4,932 Views)
Yep that worked! Thanks!
(4,927 Views)
