Tab control does not generate Value Changed Event when Value property changed.
I use a tab control with invisible tabs to display two pages of information.  I have a button on each page to switch between tabs.  Looks great and works well.  Except there is a tab control value change event case that initialises some things on the each page.  The value change event is handled if I make the tabs visible and click on them.  It is not generated when I programatically set the value on the button click event.
Any ideas what is going on there?
(3,684 Views)
Accepted by topic author ashesman1
Solved.  Needed to set the Value(Sgnl) property, not the Value property...
(3,674 Views)
Without seeing your code, I can only guess.  When you set the value of the tab control, use the property node for value(signaling).
Oops.  Late reply
(3,671 Views)
