Tab control does not allow to reduce its size
This is a simple tab control (LabVIEW 2020). But… Its size cannot be reduced by conventional dragging.
I can open its properties and set smaller size. I can set smaller size using toolbar button Resize Objects.
However! The tab control jumps to original size at first opportunity: when I try to resize it a little or when I place a new control in one of its tabs.
What could be the problem?
_____________________________________
www.azinterface.net - Interface-based multiple inheritance for LabVIEW OOP
Message 1 of 14
(4,507 Views)
I think the control is corrupted.  Delete it and recreate it.
Message 2 of 14
(4,492 Views)
I found another way to fix it: Drop any control on page 2, then delete that control.
Message 3 of 14
(4,490 Views)
Thank you Paul for your time. Unfortunately, this method does not work in my computer.
I need some simple method to fix this problem. The template is used in many places. Clones inherit the same problem. Replacing tab control everywhere manually would be a hell of work. Writing a script would also take quite a time.
Message 4 of 14
(4,432 Views)
Hi, _Y_
Try this one...
Message 5 of 14
(4,416 Views)
@diman27 wrote:
Hi, _Y_
Try this one...
Thank you. Two questions:
  1. How did you solve the problem?
  2. Why size of the tab fits to content?
Message 6 of 14
(4,410 Views)
1. I just unchecked Auto Grow in Advanced menu.
2. When Size to Fit is checked - it is normal behaviour.
Correction!
It looks like you have some hidden controls on page 1 and page 2. And it seems that this Tab Control is really broken because I can't find a way to unhide them.
If you create page 3 and then delete pages 1 and 2, everything works correctly.
Maybe recreation of pages 1 and 2 will solve your problem, without deleting Tab Control itself.
Message 7 of 14
(4,406 Views)
Correction!
If there are hidden controls, they are hidden well😀 It was my first suggestion but this script did not show any more controls:
Deleting tabs is not an option. This template was used to create many tens of clones and each is filled with controls. Manual replacements could take lot of time.
Probably I should stay with semi-solution:
  • Replace the Tab Control in the template.
  • Disable Auto Grow in all clones where the problem is encountered.
However, I have few days for waiting more replies to this forum thread.
Message 8 of 14
(4,386 Views)
Here is the fixed version.
Message 9 of 14
(4,380 Views)
@_Y_ wrote:
Does that catch everything, like decorations and stuff?
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 14
(4,360 Views)
