02-06-2008 05:11 AM
02-06-2008 06:52 AM
02-06-2008 07:53 AM
Hello Ton,
Am glad that i got a response, thanks. The following links indicate that Tab control is supported on PDA target:
http://digital.ni.com/public
http://forums.ni.com/ni/board
I feel that the Tab control property node that has been used in the VI (which is attached earlier) may not be supported on the PDA target. Can u (or any LabVIEW expert) suggest an alternate approach to achieve the same goal with LabVIEW PDA (changing colour of Tab control pages programatically)??
I had missed out some details earlier: We are using LabVIEW 8.5 PDA module on a Windows Mobile PDA.
02-06-2008 10:39 AM
02-06-2008 11:54 PM
Hello LabViewGuruWannabe,
Thanks for ur response. Version of LabVIEW that we are using: LabVIEW 8.5 Professional Development System for Windows Vista/XP/2000 and LabVIEW 8.5 PDA Module for Windows Mobile.
Since u have used Tab Control on PDA, i feel u may have come across the same situation i.e. as indicated in the attachment "VI_Error.zip". Can u please suggest me some solution so that i can get this working on the PDA? FYI, the only additional tool that i have installed on the PDA is installation of NI-VISA support. Should anything extra be done to get this working?
Expecting a solution from u...
02-07-2008 10:08 AM
02-11-2008 10:43 AM
Hi Subhashini
i think you can use design elements like an rectangle. But unfortunately it is not possible to change the hole tab with it.
see the attachment, maybe it helps.
Mike
02-11-2008 11:21 PM
Hello Mike,
Thanks again! I'll try this.
Thanks & Regards,
Subhashini
02-12-2008 06:08 AM
02-12-2008 06:15 AM
Hi Subhashini
sorry for that, but i forgot to delete the reference and the property node.
Mike
