in data 09-24-2009 05:59 PM
http://lavag.org/topic/11081-tab-control-bug/
Hi
I guess many of you have encountered this issue with the tab control.
Is this a bug or something everybody knows about and always just manage to live with it.
The problem is that the Tab Control don’t always changes Tab when you programmatically changes is using a local variable, if you at the same time updates a control or indicator using the property node which is located on any of the tabs.
Cheers,
Mikael
in data 09-24-2009 07:15 PM
in selection number to case structure you have it going to string value property node instead of string 2 value property node I think that may be your issue
in data 09-24-2009 08:16 PM
in data 09-24-2009 08:18 PM
