TRAPPING AND RECORDING AN EVENT
This is the updated VI. It is still continuously writing to the text file, perhaps I am missing something
Many thanks for your assistance
Message 11 of 19
(1,222 Views)
Invert the input from the shift register - right click on that input on the compound arithmetic node and select invert input.
Message 12 of 19
(1,213 Views)
output that is.
Message 13 of 19
(1,207 Views)
Tried inverting, but the input into the file is still continuous. Maybe I don't understand as I am completely new to this. Anyway I could send the VI ?
Message 14 of 19
(1,189 Views)
Personally I am not a fan of Feedback Nodes, a Shift Register does the same thing and does not break the data flow paradigm like FB nodes... (IMHO)
Anyway what you need to do here is what we used to call back in the day "Set a flag"
See my soultion to  How to send email when vacuum reaches threshold for an example.
=== Engineer Ambiguously ===
Message 15 of 19
(1,185 Views)
Yes, that would help.
Message 16 of 19
(1,178 Views)
I concur.
Message 17 of 19
(1,176 Views)
Hopefully I have done this correctly !
Message 18 of 19
(1,146 Views)
Accepted by topic author Tim_56
If the output is TRUE, and previous is FALSE, the IO is going up. Then you want to log. So the log should be in the TRUE case of the case structure.
Right click the case, and when showing the FALSE case, select Make this the TRUE case.
Some stuff to reflect on:
Spoiler
Alternatively, you can invert the output of the compound arithmetic node.
Then you'd have a !Log if !A NAND B, that would read as Don't not log if previous is FALSE and current is TRUE.
That could\should be refactored to A OR !B. That would  read as "don't log if previous is TRUE or current is FALSE".
In general, and AND can be changed to an OR (and vice versa) by inverting ALL inputs and outputs. If you have more then two inverted  terminals, that is usually conceptually easier.
Message 19 of 19
(1,142 Views)
