TIP incremental connector pane
I often use the create sub-vi from selection feature to reduce the code size on block diagrams. The new vi will have a connector pane layout with the minimum number of connections and I spend some time rewiring to the pattern I want. However, if I carefully chose a sequence of new connector panes, each one closer to the layout I want, eventually I get the layout and the wiring I want, and it is much faster and easier.
Message Edited by Odd_Modem on 11-09-2007 06:16 PM
Message 1 of 9
(9,963 Views)
I don't really use this as much, because it doesn't work as nicely in LV 7.0. It usually tends to take things one terminal lower than I want them.
What would be nice was if we had the ability to simply swap and move terminals on connector panes. I suppose it could be done relatively easily using scripting, but I don't feel like it.
___________________
Try to take over the world!
Message 2 of 9
(9,931 Views)
Thank you Odd_Modem!
I'm sure I'll be uisng this tip soon!
Ben
Message 3 of 9
(9,886 Views)
On a related note:
Getting the names of the connectors produced when doing "create" sub-VI can be controlled if you stop and think about what you are about to do.
The names will match-up with the source of the wires, if they come from controls. Unfortunately wires coming for other logic will have cryptic names.
For those sitiuations, I first drop free labels on the wires before doing the "create sub-VI". This way, when the sub- is created, I can just cut-n-paste the free label text to the control/indicator.
Its a  lot easier that playing "Chase the wires" trying to figure out wich wire got wire to which terminal.
Ben
Message 4 of 9
(9,885 Views)
Finally, I come into work on a Monday to find a nice, new nugget!
Message 5 of 9
(9,837 Views)
Nice nugget.
I was also recently informed of mballa's subvi fixer tool, that will change that pattern and fix the connector pane based on the arrangement of your front panel objects.  I have found it handy, just another way to do what you have suggested here Smiley Happy
Kenny
Message 6 of 9
(9,779 Views)
Hi Guys,
 I didn't know you can "create sub-vi from selection", is this a LabVIEW8.5 feature? (I'm using 8.2).
Please clarify,
   Malosh
Message 7 of 9
(8,117 Views)
No, this is not a new feature of LV8.5 but can also be done with previous versions.
  • Select part of code
  • LV menu >> Edit >> Create SubVI
Message 8 of 9
(8,114 Views)
Thanks JB! a huge useful tip!!!
I can't believe I missed it...
Message 9 of 9
(8,109 Views)
