TDMS with Action Engine (Functional Global)
Hmmm.  I'm using LV 8.5 with the DAQmx 8.6 and it works fine.  I've been using the technique almost since DAQmx came out.  I have actions like: init, calibrate, create task, config, run wave, abort task, shutdown.  I can string them together or run them stand-alone with no problem...  Curious.
K
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 11 of 14
(894 Views)
I am curious why the DAQmx stuff is working when the VI goes idle. Since DAQmx stuff now is using (?) VISA check this to see if your AE start to NOT work.
Ben
Message Edited by Ben on 03-27-2008 02:17 PM
Message 12 of 14
(885 Views)
I tried the "auto close VISA sessions" option and no change (i.e. it still works fine).
Here's the VI I'm using to control a PXI-6259 MultiFunction card but it should work for many models without modifications.  Try it out.
Message 13 of 14
(868 Views)
Forgot a couple things.  Guess I should have zipped it:
Message 14 of 14
(866 Views)
