TDMS use case multiple tests
I am asking if people find the TDMS hierarchy one level shy of perfection, or if I am mis-using the technology.  Are TDMS files intended to hold data for a single test, or are people able to store multiple tests in a single file?  Here is my use case:
I generate about 35 tests per minute.
       Each test has 3 phases/segments (warmup, run, cooldown phase)
                 Each phase/segment has 4 to 6 channels.
                           Each channel is 1D array of data.
As I understand, TDMS is a 3-tier hierarchy so I have to create a new file for each test (yuck), or use a group for each test, a channel for each phase, and reshape 2D channel data into 1D entry for a single channel.
Any other ideas?
(2,804 Views)
Accepted by jfazekas
With your use case, yes, it seems it is one level shy of perfection.
What you can try to do is have it grouped like this:
  • One TDMS File
    • Group for each test
      • A channel for each bit of information on that test
You would have to name your channels with information about what segment they were from.
Stephen B
(2,771 Views)
