TDMS to MAT
im using TDMS file for my measurements and as you can see i have multiple groups and also some properties.
I want to use the data for Matlab. So Matlab cant read my TDMS files, because its says it cant read RawData or something like that. I tried to use the NI solution: https://forums.ni.com/t5/Example-Code/Convert-TDMS-File-with-DAQmx-Raw-data-Using-LabVIEW/ta-p/35229...
After that i can open the TDMS File with matlab, but all the additional information are deleted and also there is only the data of one group (due to "TDMS Read").
So im looking for a solution to export my TDMS File with all these datas to a .mat file, i tried some matlab scripts and all are not working. Maybe you guys can help me out?
(2,008 Views)
Matlab files are now just H5 files with a special header.
On VIPM there are two utilities for H5 in VIPM. The one by Martijin Jasperse has a example for making a Matlab file.
(1,985 Views)
