TDMS Timestamp Decoding - Help!!
Can someone help me understand the result of Time stamp values when using the DIAdem .TDMS to .mat conversion tool?
In LabVIEW / DIADEM timestamp looks like this:
05/27/2016 09:54:42.0118
When converted to MATLAB it looks like this:
6.363147568201177e+10
I understand that it is converting a 128bit character into a 64bit double in MATLAB but not sure what info is actually captured or how to get real time value in MATLAB.
Basically what does 6.363147568201177e+10 mean?
Thanks for any help!!!
Message 41 of 42
(1,579 Views)
Hello BG103,
I'd try creating a new thread as this one seems a bit old and you're comment won't get the attention it needs from our community.
If you use the calculator in DIAdem and run the function RTT(6.363147568201177e+10)? it gives the date 05/27/2016, presumably this will also include the HH:MM:SS as well.
So it appears the number 6.363147568201177e+10 given to MATLAB from DIAdem is the seconds since 01/01/0000.
Hope that helps some.
Rob
Rob S
Message 42 of 42
(1,552 Views)
