TDK Lambda G Series Driver not working properly?
Hello, im using the tdk lambda g series driver to test a G6028. The hardware is connected correctly to the pc (which is remote), but when i try to run the "Set and Read Output Parameters" vi and try to read back the values the output voltage is alwas 0 while the output current is around 0.75 (if i set the current limit to 1, while if i set it higher it reads 0 as well).
Anyone can help me?
(730 Views)
Did you check the turbo encabulator? That's the best advice I can offer without any code.
aputman
(681 Views)
