TCP write buffer problem...
This is a real newbie question, but here it is...
I'm connecting to a device using the TCP vi's.
Here's the problem... if I write "12345" (5 chars) all is good. Then if I write "ABC" (3 chars) the device is receiving "ABC45" (5 chars). Its like the write
buffer isnt being reset. It still contains what was written previously. The device I'm talking to doesnt like CRLF pairs, so thats not an option.
On a related note... I'm using the TCP vi's for this. Its just a plain TCP\IP connection.
Should I stick with the TCP vi's or use VISA vi's instead?
On one more related note... Does LV have a null character (\0)? I was told that that the device uses the null char to determine the end of the command.
Maybe thats my problem.
(4,272 Views)
Hi WayneS1324,
to what type of device are you connected? Could it be, that you receive the 3 Bytes correctly, but don't overwrite the 2 other bytes? Did you test your vi on your local pc? You can use the tcp server example for it.
Can you show the code you have used for your test?
Mike
(4,266 Views)
Thanks for the replay Mike.
Unfortunately I can't post code or any other information. I'll have to rely on my explanatory skills (which are lacking!).
If I send "12345" and then "ABC" I can verify that the "ABC" is sent and the device receives "ABC45".
I'm thinking that my answer may be the null character but I cant seem to find that in LV and the TCP write only accepts strings.
I appreciate the patience... the fact is I know next to nothing about TCP. I've just been thrown into the deep end of the pool.
[EDIT] I wrote some test code (PC to PC) and it did seem to work that way. It could be that the device needs its read buffer flushed.
(4,263 Views)
Accepted by WayneS1324
I found the null char. A string constant set to hex display 0x00.
I'll try that.
(4,260 Views)
