TCP error 66
Guys,
I am currently trying to read from a RFID Reader application known as TAVIS. It has a TCP/IP address (192.168.1.1) with a port at 6700.
Attached is a simple Vi that i have made to read from that port. I could get readings from that port successfully. However, after taking approx 6-8 readings of 60Bytes of data, the program crashes with an error 66. (error attached). I would need that this VI take active readings off the port continueously.
Kindly advice on how i can rectify this problem.
Thanks a lot guys.
Cheers,
Justin
(3,972 Views)
search the forum with that error code you will find lot of discussions. Post back if your problem is still persisting.
Mathan
(3,961 Views)
Mathan,
I did already check the forum for this error before i post this. However, most of them post with regards to other issues, and seems to rectify it by solving other unrelated issues in their VI.
Anyway, there was 1 of them which states to "remove the while loop". I dun get what he meant by that, as i do need the while loop to continuously attain/read data from the specified port of my RFID Reader TAVIS application.
Thanks for your suggestions. Kindly advice further Smiley Happy
Cheers,
Justin
(3,955 Views)
Are you sure about the IP address?  IP 192.168.1.1 sounds more like a router address then the IP address of some other device.
(3,918 Views)
