TCP acknowledgement problem
I have a TCP server and client communication project in which PC with labview application is the client. I am not getting acknowledgement from the  labview application. I want to check acknowledgement for reliable communication. Please suggest any methods ???
(4,800 Views)
We need to see your VI first. What have you done so far?
(4,753 Views)
What acknowledgement do you want to see? If you are referring to the actual TCP ACK you will not be able to see these. Those are handled at the stack level. Any other type of acknowledgement you would see would be part of the actual protocol itself.  For example, the FTP protocol will always send a response to a command. This would be your acknowledgement. If you are not getting any errors on your TCP Open, Read or Write you should be fine. If you have no errors and things are not working it is most likely your implementation of whatever protocol you are using.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(4,739 Views)
I am not getting any errors on my TCP Open, Read or Write functions. My labview application is hosted on cloud. microcontroler device is sending TCP packets to labview application hosted on cloud and in labview application i am reading TCP data and  writing to the database.  Previously labview application was acknowledging upon data receival to the microcontroller unit. But now it's not acknowledging the data receival.
(4,720 Views)
Mark Yedinak
(4,718 Views)
You did not answer my question. What ACK are you looking for? Can you post your code so we can see what you are doing? What ports are you using? Have you verified that there are no firewall issues which maybe blocking your communication?
Mark Yedinak
LabVIEW Champion
(4,626 Views)
