TCP Socket c# Project to LV
Hello i have a little Problem.
I want to upgrad an old program with an 3rd party TCP Client to LV
The Server accept the following protocoll
length of message [2 byte]
Message [n byte]
EOT [1byte]
the 3rd Party sends the data with the following code
private static void SendBytes(string data, Stream nwstream) //adjusts bytes to protocoll
            byte[] ba = Encoding.UTF8.GetBytes(data);
            byte[] bstart = BitConverter.GetBytes(Convert.ToInt16(ba.Length));
            byte eot = 0x04;
            //Adjust Bytes to Protocoll
        for (int i = 0; i < bstart.Length; i++) //message length
                nwstream.WriteByte(bstart[i]);
            for (int i = 0; i < ba.Length; i++) //message length
                nwstream.WriteByte(ba[i]);
            nwstream.WriteByte(eot); //Message Endoftransmission
        private static string sendtoServer(string xmldata)
            TcpClient tcpclnt = new TcpClient();
            try
                tcpclnt.Connect(ipadress, port);
            catch
                System.IO.File.WriteAllText("/home/pi/files/init/error.txt","NoConnection");
                System.Environment.Exit(1);
            Stream nwstream = tcpclnt.GetStream();
            SendBytes(xmldata, nwstream);
            StreamReader nwreader = new StreamReader(nwstream, Encoding.UTF8);
            String response;
            try
                response = nwreader.ReadToEnd();
            finally
                nwreader.Close();
            tcpclnt.Close();
            return response;
Maby someone can help me
best regards
Alex
(1,953 Views)
Do you want to create equivalent LabVIEW code for your C# code or is it about creating a TCP/IP Server that can handle this C# client?
Rolf Kalbermatter  My Blog
(1,920 Views)
Hello and thanks for replay
i want to create an equivalent LV code
best regards
Alex
(1,911 Views)
Accepted by topic author KTM_Lex
This is pretty much it.
But there might be something with the TCP Read. LabVIEW doesn't really know the equivalent of Stream.ReadToEnd, since there is no clearly defined end. Standard mode might work, and if your response can get bigger than 1000 bytes you would have to increase the number of bytes to read.
(1,897 Views)
Thanks for the very fast replay, its perfect
i tryed it with many other moduls but i didn't get the right way to send the message length and eot
thanks so many times
(1,885 Views)
