TCP Packet Size Limitations
In working with TCP connections over the years, I discovered that I could not send more than about 1500 bytes in a single TCP WRITE operation without it failing.
I don't remember the exact number, but there was a point where I could send N bytes in a packet and it would work every time, and if I sent N+1, it would fail every time. That point was somewhere around N=1500.
So I ended up breaking everything up into chunks of 1000 or so, and that worked just fine.
Recently, on a new project, I did not think about that limitation, and ended up having a chunk of over 3500 bytes in a single TCP WRITE, and it worked!
Perfectly. First time, every time.
So what are the rules here? Have the restrictions relaxed over the years? Does the fact that I am now on a simple Win2K - D-Link Router - PXI box connection (with 3 other computers) make a difference (versus whatever corporate environment I was in before, with a thousand computers).
Do I still need to break it up, because maybe my client has a different environment, or am I safe as it is?
Can someone explain the rules, or point me to where they are explained?
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 1 of 14
(10,894 Views)
The maximum packet size depends on the MTU of the link. You are probably talking about the payload size. The total packet size also includes headers (ethernet, IP, TCP) and checksum, etc. Fortunately, TCP/IP will automatically fragment the packets according to the link characteristics. (e.g. VPN and PPPoE links are lower due to the additional headers).
However, none of the TCP/IP tools in LabVIEW care about the details of the transmission. They are NOT packet oriented. They are connection oriented. Size should not be an issue.
Open the example "simple data client/simple data server and set the size to e.g. 20000. There is no problem!
Message 2 of 14
(10,877 Views)
Hi Coastal,
I can not point at references...
I can not explain why you ran into the  N= 1500 limit.
The TCP part of TCP/IP is responcible for breaking a tranimited packet into small enough chunks to be transported (VIA IP) and enusring all of the pieces arive at the destination and are properly rea-assembled. It is only after everything is back together at the recieving end that the TCP/IP nodes should return a recieved packet.
So I do not know of an upper limit!
Another factor that comes into play is the Naegel (sp?) algorithm. Inside the TCP/IP stack (somewhere) an attempt is made to optimize network throughput by avoiding sending many small packets, by allowing the packets to pile up and send everything at once. I seem to remember that the optimal ethernet packet size being about 1500 bytes. The Naegel algorithm will affect how long after a transmit request is issued, the data packets are put on the wire.
That is all I can say for now.
Take care,
Ben
Message 3 of 14
(10,874 Views)
Perhaps "packet" is indeed the wrong word - I was referring to the size of the TCP WRITE string, which would count as "payload", I suppose.
However, I clearly remember having the problem some years ago, and broke up file transmissions (for example) into blocks of 1024 bytes to avoid it.
Is the MTU an adjustable number on Win machines? Is it possible that the MTU on the machine I was dealing with was set to 1500 or so?
When I had a satellite Internet link, I remember adjusting the MTU on my Mac to enhance that somehow, but it wasn't permanent.
Is it then your opinion that my break-up-files-into-pieces approach is unnecessary?
Thanks.
Steve Bird
Culverson.com
LinkedIn
Message 4 of 14
(10,867 Views)
1500 is the standard Ethernet MTU, that is, for Ethernet packets, so you need to strip away a bunch of bytes for the TCP over Ethernet max packet size.
However, as Altenbach pointed out, at a higher level TCP should be able to manage fragmentation, so the actual size should not be a problem, or at least it should be tied to a much higher limit.
Paolo
Message 5 of 14
(10,861 Views)
There is no size limitation and the help does not mention any. Of course you should follow the guidelines in the help so your application on the receiveing end is aware when the transmission is over. (prepend size in string, use constant portion size, use delimiter, etc.).
You are only dealing with OSI layer 7 (http://en.wikipedia.org/wiki/OSI_model)
Message 6 of 14
(10,857 Views)
So you are saying that it IS necessary to break up the payload...
Then I don't understand why I do NOT have the problem now... I have ethernet from CPU to ROUTER to PXI box.
Steve Bird
Culverson.com
LinkedIn
Message 7 of 14
(10,849 Views)
Yes, I am sending a one-byte COMMAND and a two-byte SIZE in front of my current payloads. It works just fine, but my question is will it work on my client's setup?
My client happens to be the very place where I previously worked, and experienced the problem.
I'm wondering where the limit comes from: you say there isn't one, pincpainter says there is. I used to have a limit, now I don't (or at least it's a larger limit, I haven't tested more than 3500 bytes).
So I'm still confused.
Steve Bird
Culverson.com
LinkedIn
Message 8 of 14
(10,844 Views)
I meant that the TCP protocol stack would manage the stuff for you. For example, if you write a 5k bytes message, an intermediate software layer will break up the message to four packets. On the receiver side, a similar software will catch up the four packets and reassemble the content possibly into a single message. This is transparent to your application.
(Of course, IF the MTU is really 1500 bytes, and there is no non-standard extension)
Message Edited by pincpanter on 03-01-2007 05:45 PM
Paolo
Message 9 of 14
(10,843 Views)
Oh. I misunderstood the "you need to strip away some bytes for overhead" part of your post.
So you agree that there should be no problem?
I wonder why I experienced the problem a while back?
I know that I spent enough time on it to verify that I could send N, but not N+1 in a single operation.
If I send a megabyte file with a single TCP WRITE, is it synchronous, or asynchronous? Is it going to hang my program until all the bytes go out the wire, or do they go into a buffer somewhere for the OS to handle?
I guess I can find that out myself...
Steve Bird
Culverson.com
LinkedIn
Message 10 of 14
(10,830 Views)
