TCP\IP basics
HI,
     I'm doing a project in labview , the  below are the few details of the project.
1)  Embedded Controller (Ni PXI 8106) is connected to a Machine. This controller acts as a server, the server  code is written in cvi. The tdms files which are gathered from Machine is stored on this embedded controller (server).
2)  Pc with Labview which acts as a client .
      The task is to access the Controller using TCP/IP from labview programme (client)  and to get tdms data or channels and plot in labview.
       So how do i start to program the client? or If there are any examples wrt accessing tdms files on server and then plotting in labview, pls do post?
(2,412 Views)
Duplicate post
Kindly stick to a single thread. Somebody will post a reply and help you out there if you keep all your similar queries tracked in a single thread.
Mathan
(2,404 Views)
