SystemExec.vi working directory problem
I am trying to use the SystemExec.vi to open an executable file in a non-labview directory. If I enter the entire path and executable name in the VI's command line input everything works as expected {C:\temp\test\software\program.exe}. If instead, I enter the path in the working directory input {C:\temp\test\software} and the executable name in the command line input {program.exe} I get error code 2. Am I missing something with the syntax or is this VI defective or ???
Labview 6.1, Windows 2000
Any help would be appreciated!!
(3,144 Views)
I believe the working directory is where any output files would be placed if not specified otherwise.
Ben
(3,144 Views)
Command line: C:\temp\test\software\program.exe
Working Dir: C:\temp\test\software
See attached (6.0.2)
ian
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,144 Views)
This is the correct solution...
Note any shortcuts you have in Windows 2000. The full path and working directory are listed as stated above.
(3,144 Views)
A better solution for System Exec.vi here
Ian F
依恩与LabVIEW
(3,144 Views)
