System.windows.Controls Spellchecker class
I'm new to LabVIEW and trying to explore few .net function's and I tried using System.Windows.Controls(Presentation.dll) spellcheck on a Richtextbox, But doing so my application crashes when I launch a RichTextBox control, So I tried using TextBoxBase but I get this error.
Excpetion : Invoke Node Error calling method System.Windows.Controls.Primitives.TextBoxBase.AppendText, (System.ArgumentNullException: Key cannot be null.
Parameter name: key) <append><b>System.ArgumentNullException</b> in SpellCheck.vi
Can someone let me know how I can perform spell check using
Namespace:   System.Windows.Controls
Assembly:  PresentationFramework (in PresentationFramework.dll)
Mounica Lekkala
(2,729 Views)
I think you picked a bad one to get started. It's not going to be easy.
Most (not if they're static) .net objects need to be created. So you need to either create a control on your front panel, or use a constructor to get an object. The TextBox has a problem that the thread needs special privileges. Not sure how to resolve that. TextBoxBase does doesn't have a valid constructor. Also not sure how to resolve that.
Pick your battles. If you don't require this, try something else. This one's for experts. Even if someone post a working example, you won't learn a thing.
(2,699 Views)
