Syntax to Save/Export Mathscript Plot to bmp file
I just found out that LabVIEW mathscript uses the same syntax as Matlab which is AWESOME! I love it!
So, now I'm processing some data and need to plot them. I find that the mathscript plot easier to edit/adjust compared to the waveform chart or x-y graph. My only problem now is that I do not know how to save/export the mathscript plot window to bmp or jpeg. I tried using the Matlab syntax "saveas" but it didn't work. I know I can export the plot if I go to File, then Saveas bmp, but I have a lot of plots and I need to have it done automatically. Is there a syntax that can be used to do this?
I'm using LabVIEW 8.2. I would really appreciate some help.
Thanks!
Haris
(3,358 Views)
See this response (found from a search).
(3,347 Views)
