Synchrophasor
Hi Suryas,
According to the requirements found in the Example Finder, you'll need to use an NI-9467 module in a cRIO chassis in order to properly run the synchrophasor example. Do you have access to any of this hardware?
Nick
Message 11 of 14
(1,102 Views)
Hi! I have NI - 9075 cRIO Hardware. Thanks, surya S
Message 12 of 14
(1,097 Views)
Hi Surya,
So the example program cannot run on the NI 9075. If you are in the example finder and look at the Requirements section, it says that the devices that can run the example are cRIO-9068 and NI 9467. If you're trying to use this example without the hardware, you will have difficulty getting correct measurements and you may not be able to run the code at all.
Unfortunately, the NI - 9075 cRIO is a legacy product and is not listed as one of the devices that can run this example.
What errors are you currently running into when trying to run this code?
Zoe B.
Account Manager - Pacific Northwest
Message 13 of 14
(1,071 Views)
HI!
I am Getting this error when i run the example of Synchrophasor.
Surya S
Message 14 of 14
(1,036 Views)
