‎03-15-2017 11:54 AM
I am asking for help doing this:
Can I have your help on how to do this?
Thank you.
Duarte
Solved! Go to Solution.
‎03-15-2017 12:17 PM - edited ‎03-15-2017 12:18 PM
‎03-15-2017 12:27 PM
There are many different solutions. Here is one, not necessarily the most optimal in terms of speed etc, but can give you idea... Whatever solution you use, it is important that you need to limit the size of the log, otherwise you get a memory leak.
Here is the snippet (drag and drop into an empty block diagram):
‎03-20-2017 08:49 AM
I did it.
Thanks.
