Switching from sinusoidal AC voltage to DC offset
Hi there,
I am attempting to generate a continuous AC sinusoidal signal output which will change to a DC offset when triggered with a push button, and if not triggered will continue indefinitely. Producing the continuous AC signal in a while loop is working fine (using waveform buffer generation (multi) VI), however getting the code to change to a DC offset is proving difficult.
I have attached an image which shows the idea behind what I am trying to do a bit better.
The output card is a NI 9263 output card in a cDAQ-9188 chassis.
(2,817 Views)
What have you tried?  Attach your VI.
You are basically looking for a case structure that will either output the sine waveform continuously, or output a single value that is your DC voltage.
(2,786 Views)
Hi there, I have attached my VI in a .zip file. If you have any pointers it would be greatly appreciated!!
(2,733 Views)
