Switch on bulb using PCI-6254
Hello everyone,
For the purpose of synchronizing visual and IR recordings of test, I am trying to use my PCI 6251 to produce a digital output that could light a common small light bulb ( let's say similar to the ones you could see in your bike light, right now I have bulbs from 1.5V to 6.5V, can use any of them).
Image synchronization should be achieved by lighting a small light bulb which could be the reference frame of both visual and IR recordings. The problem was that IR cameras cannot detect LED light or IR LED light ( out of wavelength range) so I need to use a more ''hot'' bulb like these common incandescent bulbs.
Neither AO or Digital output signals can supply directly the required power to light such a bulb. So I was thinking using the digital output to drive a relay that could switch on/off a battery supply ( or a small mains to DC transformer).
Could you please help me out of how I can do that?I am not very good with electronic components and even though I read in the forumn about solid state relays, I am very confused of how I can actually implement such a solution.
I thank you in advance.
(2,563 Views)
Do a search for "Solid State Relay" (SSR), these are devices which can be switched by a logic signal without requiring excessive drive current from your DAQ device. As you have noted, the DAQ device isn't designed to supply the relatively high current 10X - 100x mA) needed by an incandecent lamp, are actually only designed to supply a signal level of relatively low current ( a few mA). Most SSR will also require their own DC supply, but this can probably be the same one used to power the lamp.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,553 Views)
