Summing the last n elements of a array
I'm collecting data from an instrument once per minute and adding each value to an array. After many days there are alot of values in the array. I want to be able to select a time, ie 4 hours, and have the last 4 hours of values added together so it can be displayed. Any ideas. Thanks in advance for the help.
ssmith
Message 1 of 8
(6,313 Views)
Accepted by ssmith490D
Use Array Subset and Add Array Elements.
Once per minute = 60 values per hour.
Number of Hours * 60 = number of elements you want.
So subtract Number of Elements from Array Size to get your index.
Quick and easy!
8-)
Message Edited by LabViewGuruWannabe on 12-26-2008 03:39 PM
Message Edited by LabViewGuruWannabe on 12-26-2008 03:40 PM
Message 2 of 8
(6,307 Views)
hello,
try this
Arg my pc is too slow  :smileywink:
Message Edité par tinnitus le 12-26-2008 03:40 PM
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 3 of 8
(6,299 Views)
Message 4 of 8
(6,293 Views)
I'm guessing this is a continuation of this thread, so my suggestion below is based on this. In the screenshot you posted you are using Build Array. A couple of points first:
  • Be aware that this operation will slow down your program over time, as you are continuously increasing the memory footprint by growing your array.
  • You do not need to use local variables to do that operation. Use a shift register that's attached to your outer while loop.
Now, as to your question: Since your samples are not evenly spaced, then you must determine where to take an array subset. To do this you need to know what the time was 4 hours ago, and determine which array element is beyond this. You can accomplish this by a simple comparison operator and then search the 1D array for the first True/False. This tells you where the 4-hour cutoff is, and where you can take the Array Subset.
Message 5 of 8
(6,289 Views)
tinnitus wrote:
try this
From the other thread, it seems that ssmith is using LabVIEW 7.1. Attaching a 8.6 VI without any explanation is not very helpful.
Message 6 of 8
(6,275 Views)
hello altenbach,
there is a simple chain with simulated aquisition that a child could understand,
about 7.1.1 it 's written nowhere, on simple demand i can also repost or send a pict
good night ( at least for me)
Tinnitus
Message 7 of 8
(6,261 Views)
Thanks a lot. Works great.
ssmith
Message 8 of 8
(6,243 Views)
