Summation not equal
See attached VI, can anyone explain why this weird thing happens:
I extracted the 1st element of waveform and changed it to a control, I tested it is equal to the 1st element in the waveform. And then I do a summation using the 1st element in the waveform and controls, they are not equal?
(2,625 Views)
Accepted by Chuan
Hi Chuan,
they are not equal?
Do you know the difference between SGL and DBL datatypes?
If you know then I wonder about your question.
I not, then you should learn about it!
You forgot to note you also changed its representation…
General lesson learned (again after all those threads on the very same problem): NEVER compare floats for equality!
(2,616 Views)
