Sum of array element
I'd like to perform a sum of elements of an array, using "For Loop" and "Formula Node" only. I wrote this program but it does not work. Can anybody advise?
Thanks..
(8,960 Views)
Hi Splee,
Can you please post the vi in an earlier LV format (I have 8.5)?
(8,956 Views)
here is the v8.5 version..
(8,953 Views)
Why do you use Formula node? To hold on to the previous value in a for loop, I think you have to use a shift register.
(8,938 Views)
I'm not sure if that's what you meant, but it's working now (with slight modifications).
You can do it without a for loop too....
Hope this helps,
A
(8,935 Views)
Hi,You can also use the add array elements to do it directly.
LabVIEW 8.2,8.6,2009...still learning 😛
(8,915 Views)
