Subtraction between timestamps
Good morning.
Working with subtraction between timestamp data, I'm encountering seemingly nonsensical behavior, which is becoming quite a headache for the algorithm I'm trying to develop.
Specifically, given that the subtraction between 2 timestamps gives me a double as a result, which effectively represents the number of seconds that elapse between the 2 instants, if I try to convert this number into a new timestamp, the result I get is invariably a hour more than the actual difference between the 2 times.
What is it that's slipping away?
Thanks to everyone who can give me a hand
(25,157 Views)
Accepted by guada_bl
Try to convert just 1 second with and without UTC, this should explain everything for you:
(25,140 Views)
The Time Stamp control/indicator/constant display based on your system's time zone.  I'm pretty certain I saw a nugget about having the Time Stamp display in UTC, which would display the 7 hour that you are looking for.  I just don't remember how to do it at the moment.
(25,134 Views)
Great point, Andrey Dmitriev.
Indeed, checking the documentation of the "To Time Stamp Function " it is specified that "time stamp is a time-zone-independent number of seconds that have elapsed since 12:00 a.m., Friday, January 1, 1904, Universal Time [01-01-1904 00:00:00]."
Thak you so much
(25,126 Views)
I just found the trick.  Right-click on the timestamp and choose "Display Format".  Choose the "Advanced editing mode" on the bottom of the dialog and then change the Format String to "%^<%.3X %x>T".  The %^<>T format is described as "Universal time container".   So by just inserting that carrot to the front will make the display use UTC instead of your local time zone.
(25,105 Views)
