08-26-2011 12:08 PM
Hi. I have a VI that encapsulates some camera "Stuff" that I want to do.
I would like to use this stand alone VI in another VI that has a tab container on it.
When I add the camera VI as a subVI I can see the icon in the block diagram but I can't find the Front Panel for the SubVI. Any ideas what I'm doing wrong?
Thanks!
08-26-2011
12:14 PM
- last edited on
08-11-2025
09:34 AM
by
Content Cleaner
https://www.ni.com/docs/en-US/bundle/labview/page/loading-a-front-panel-in-a-subpanel-control.html
It's possible to do, but in my experience, it'll make the SubVi pretty slow.
You might consider redesigning the VI so that you can loop over the SubVI for updated information, and then use UI elements on the top level VI to display that VI.
Alernatively, you could open a VI reference and run it in another window.
Hope that helps!
- Chris
08-26-2011 12:22 PM
Thanks Chris.
I will just put all the code in the same VI. Is there a way to group a number of controls together so they 'act' as one when moving things around?
08-26-2011
12:27 PM
- last edited on
08-11-2025
09:34 AM
by
Content Cleaner
Scroll down to creating clusters:
http://zone.ni.com/devzone/cda/tut/p/id/7571
08-26-2011 12:30 PM - edited 08-26-2011 12:30 PM
Or perhaps you are referring to simple grouping:
This and other interesting tidbits can be uncovered in that incredible document that rivals the Magna Carta. No, it's not War and Peace. It's the LabVIEW Manual.
08-26-2011 12:35 PM
smercurio_Fc.... that's the trick!
