Developer error when installing Labview 2010
Dear Administrator,
I uninstalled my old version of Labview 7.1 with Windows "Programs and Features", and try to install Labview 2010. However, error occurs.
It says:
" Developer Error. The following errors were found in your ini file:
1. Specified file not found: [Utilities] UpgradeManagerPostProcessro = bin\nipie.exe
2. Specified file not found: [Utilities] NISysinfo = C:\Users\...\NI.LabVIEW.2010.v10.0\bin\NISysInf.dll
Correct the ini file and try again."
My system is WIN 7 English version.
Help please.
(4,349 Views)
I tried to download the nipie.exe and NISysinf.ini in previous posts which applys to Labview 8.x. They didn't work. Maybe I need a new version of these two files?
(4,348 Views)
no one help?Smiley Sad
(4,333 Views)
In the past this has been caused by faulty discs or an antivirus program. Where are you running the installer from? If it's from disc try copying the whole disc to your hard drive and running it from there. Did you download the installer? You might want to try re-downloading it. Do you make sure to turn off your anti-virus program? Do you have admin rights?
(4,329 Views)
I read some past posts on this issue, but the problem is not solved.
The software was installed from Harddrive, anti-virus programes were turned off. Problem is still there!
(4,321 Views)
The first step I reccomend you try is to re-download the LabVIEW installer, and try to run it again.  Also, make sure you have Administrator access on your computer.
You can download LabVIEW here.
Matt M.
(4,313 Views)
