SubVI not executable: many express VIs cannot be opened
When I create an icon of an express VI on the Block Diagram, "error loading National Instruments\LabVIEW 2012\resource\lvanlys.dll" appears. And when I double click the icon, it is shown on the screen "unable to view properties". I cannot run the VI, and the errors listed are like "SubVI 'simulate signal': SubVI is not executable". I do not know how to solve this problem.
Hope someone can help me. Thanks a lot!
(4,573 Views)
What do you mean "create an icon of an express VI on the Block Diagram"?  Give us enough steps to be able to reproduce (or test) your problem.  Include:
  • Are you starting with a "blank" VI or a blank Project, i.e. starting from scratch?
  • What is on the Block Diagram before you "create the icon of an express VI"?
  • Which Express VI are you trying to use?
(4,546 Views)
You don't really provide enough information (LabVIEW version, number of CPU cores, etc.) to pinpoint the problem, but I suspect that you might have an issue with the intel MKL. See if this fixes your problem.
(4,538 Views)
  • I started with an blank VI.
  • Nothing is on the Block Diagram.
  • I used Simulate Signal, Simulate Arbitrary Signal, Filter and Amplitude & Level Measurements, and all encountered the problem I described.
(4,523 Views)
My version is LabVIEW 2012, and there are four CPU cores.
(4,521 Views)
Thanks.  You really do have a problem.  It sounds like a possibly bad or incomplete installation of LabVIEW.  One quick "reality check" is to look in C:\Program Files (x86)\National Instruments\LabVIEW 2012\resource and see if you can find lvanlys.dll.  [The path is for a Windows 7/X64 system -- your path might vary slightly].  I'll bet the .dll is missing ...
If so, a reinstallation might fix things (but why it didn't install correctly is a mystery).
(4,493 Views)
As a next step, simply repair the installation and see if things improve.
(4,474 Views)
