Sub vi quits when stopped
Hello everyone,
I have a main code that calls some sub vi's using reference. The sub vi opens properly and works just fine.
When I press stop on the front panel in the exe, the sub vi is supposed to just stop and not close its front panel as there is no such code inside the sub vi. But the front panel still closes. This does not happen if I run the code (the vi) on the same computer. I guess there must be some settings I need to do when I create the exe. I have used LabVIEW 2014 64bit on windows 10, 64 bit.
Any help with this is appreciated.
Thanks a lot
(2,561 Views)
Share the code Module for Reference.
Mean While "Check the VI Properties--->Window appearance--->Cutomize and Uncheck Close Front panel if originally Closed".
(2,547 Views)
A stopped VI (i.e. edit mode) makes no sense for an executable. Create a proper state machine instead and place the caller into an idle state instead of stopping it.
(2,519 Views)
