Stuck in 3D array
Hi all. I am trying to constitute a vi-attached- but I have a problem. Outside of the while loop I have a 3D array. Even if I make enabled index I could not see the all values at the end of the program. How can I see and save all values?
Egemen
(3,313 Views)
Accepted by topic author newbieeng
You need to leave out the three build arrays for the three inputs, go back to a 2D array outside of the loop and Transpose your chart.
(3,308 Views)
Hi newbie,
I can see al values - simply change the indices of your "Array"...
(3,304 Views)
Thank you lanW. It works great.
Egemen
(3,296 Views)
Glad to hear it's working as you wanted.
Regards
Ian
(3,292 Views)
