Connection to a step motor via usb
Hello.
I'm using a step motor with mini usb port in it. http://www.trinamic.com/index.php?option=com_content&view=article&id=247&Itemid=359
I have installed the usb driver from the link above. So it's visible in MAX (com 3) but I can't see it in the list of targets and in the list of connected instruments in the Instrument Driver Finder.
Can anybody help me, please? Thanks!
P.s I'm new to LabView.
(2,897 Views)
Hi Oleksiy_K,
it seems the device has as interface a virtual COM port, that you can also see within the MAX.
As I interprete the situation you have to use the VISA API within LabVIEW to programm the communication with your hadware device.
I found documentation on the device's manufacturer that contain the commands...
PDx-140-42-SE / TMCM-140-42-SE TMCL™ Firmware Manual (V1.05 / 2009-OCT-21)
http://www.trinamic.com/tmctechlibcd/PANdrives/PD-140-42/PD-140-42-SE_TMCL_firmware_manual.pdf
As far is I know you have to create the LabVIEW Interface by your own, because there is no one publicly available.
Kind regards
Tobias S.
(2,857 Views)
