04-04-2017 02:57 AM
Bonjour,
J'aimerai savoir si il est possible d'intégrer un "OU" dans la condition d'une structure condition.
J'ai un menu déroulant de texte en entrée de ma structure composé de choix A, choix B, choix C.
Je souhaiterai alors faire:
Si j'ai le choix A ou le choix B, j'allume la led 1
Si j'ai le choix C, j'allume la led 2 (voir le programme en pièce jointe)
Avez-vous des idées ?
Merci par avance
Hello world,
I would like to know if it's possible to integrate an "OR" between two conditions inside the condition structure.
I configure a drop down menu of characters composed by three possibilities A, B and C.
I would like to do :
If I get choice A or choice B, I switch on the led 1
If I get choice C, I switch on the led 2 (open the attached software)
Have you got any ideas ?
Gabriel Leroy
04-04-2017
03:04 AM
- last edited on
03-10-2026
10:42 AM
by
Content Cleaner
Hi gleroy,
write the condition as "A", "B" instead of "A" or "B" - as is described in the help for the case structure!
04-04-2017 03:05 AM
/Y
04-04-2017 03:06 AM
Ah, string. Listen to Gerd. 🙂
/Y
04-04-2017 03:12 AM
Thank you
I will try it and I will tell you if it's ok
Have a good day
