Strip data array like Strip chart
I'm wondering is there any example or hint that I can use to generate a strip data array like strip chart
Example; I wanted to update a new data and remove old data within 1000 data array. So new data will be placed in n+1, while old will be removed as n-1.
(3,275 Views)
What you're looking for is called a circular buffer. You can create one using Initialize Array (to create an array of the appropriate size), Replace Array Subset (to switch out elements) and perhaps the Quotient and Remainder function, to determine the index to replace.
GCentral
(3,255 Views)
Or just use the Data Queue PtByPt VI.
(3,239 Views)
Well, you learn something new every day...
GCentral
(3,230 Views)
