String to Shared Variable error
Hi all
I created a small example.
Why is in Shared Variable "Da 5" - "a"  not upper ?
Regards.
Iskander
(3,089 Views)
Hi Iskander,
Would you be willing to provide some system information?  What Version of LabVIEW are you using and what operating system?  I am also seeing the inconsistency when running the program.
Thanks!
Cole R.
Software Engineer
(3,062 Views)
Hi Cole R.
Thanks for attention.
I am using LV-2010 and Win XP.
I have the same ERROR "Da5" in SVE. (See example) .
Although I created in project "DA5"
Picture is added.
Best regards
Iskander.
(3,055 Views)
Iskander,
After reviewing the VI and experimenting with the issue on multiple computers running Windows 7 and LabVIEW 2011, I will be filing a corrective action request on the anomoly. It is interesting that the a is only turned to lower case when the 5 is present.
Cole R.
Software Engineer
(3,042 Views)
