String separation
I'm sorry if it has been already asked but I'm facing some troubles concerning string splitting.
I have a serial port that gives me a string of hexadecimal numbers : for example : \02P\00\03\CF\01\02\00\FD\03
In here, I would like to get the numbers  : 03CF , 0102  and 00FD which corresponds to 3 variables that my sensor is measuring.
I tried using the Search/Split String Function and I have succeeded in separating my string in fragments : \03 or \CF for example.
However, I can't get past this point and remove the backslah '\'.
When I used the String length function on \03 it gave me 1...
I want to separate those strings so I can convert them afterwards using the Hexadecimal String to Number Function
Thank you in advance...
(3,173 Views)
Accepted by topic author felibonobo
It sounds like you have "\ Codes" display turned on.  I think you should change it to Hexadecimal display to make it look more like what you want to see.
So it sounds like you already have a binary/flattened string.  So just use Unflatten From String to create an array of U16.
(3,136 Views)
