String indicator color
Hi guys I want to know if it is possible to change the color of the string indicator twice depending on the input. For example on the same string indicator I want the red color when the result of the test is False and the green one when the test is passed. Is it possible?
Message 1 of 9
(5,459 Views)
You can change it as many times as you want using a property node. You can change the font color, background color, or both.
Message 2 of 9
(5,457 Views)
hi alten could you please provide me an example?Thank you
I see how to change the colour of the written but I don't know the number that correspond to each color.
Message 3 of 9
(5,451 Views)
Use a colorbox constant instead of a numeric!
Message 4 of 9
(5,444 Views)
mmm I tried in this way:
128 should be green.... but doesn't work
Message 5 of 9
(5,440 Views)
Accepted by topic author inuyasha84
Message 6 of 9
(5,439 Views)
oh nice but one more question how have you created that colored square?
Thank you
EDIT: you used the color box. I have never seen it before. Thank you for your help 🙂
Message 7 of 9
(5,436 Views)
Why? Green is 065280. It is easier of you set the display format to hexadecimal. Green is 00FF00.
Still, using a colorbox constant is much easier to use. It can be found in the "graphics&sound...picture functions" palette.
(See also this old idea)
Message 8 of 9
(5,434 Views)
Yea I have edited my last message.
Thank you for your help. I'll give a look also to your last link
Message 9 of 9
(5,430 Views)
