09-19-2013 06:35 AM
I am measuring the shaft rpm using the encoder and feeding it to the 9411 card.Can the 9411 card display the shaft rpm? How the card can do this conversion?Should I use any other component to decode the digital input pulse?
09-19-2013
07:00 AM
- last edited on
11-21-2025
12:22 PM
by
Content Cleaner
Have you tried enough searching, here and there...??
1. Check page # 12 of this manual.
2. How Do I Use a Quadrature Encoder with My Data Acquisition Board?
3. Encoder Measurements: How-To Guide.
Edited:
4. NI 9411 Pinout.
09-20-2013 12:37 AM
Thanks for the link which you provided.It was useful.
09-20-2013 12:57 AM
So if it has solved your problem, you can mark my earlier reply as solution.
