String conversion only one past number
Why do I only get one past number?
STRING [XXXXX.XXXXXXXX] => FLOAT [XXXXX.X]
extended float to default did not help 😞
(3,119 Views)
Accepted by topic author DerBachelor
your numeric indicator is set to display 6 digits of precision
(3,117 Views)
Correction: it is currently set up to display 6 Significant Digits.  And since you have 5 digits before the decimal point, you only get 1 digit displayed after the decimal point.  If you change to Digits of Precision, you will see more numbers after the decimal point.
So the data is actually correct, it is just how you are displaying it.
(3,114 Views)
Hahaha you got to  be kidding me Smiley LOL
Thanks a lot !
(3,108 Views)
Correct again, crossrulz.
(3,086 Views)
