String comparisons
Greetings,
I  am a neophyte user (stating the obvious here) having trouble with string comparisons. The little vi attached ran an turned green one time but forever after I cannot get it to indicate green regardless of input.
My eventual goal will be to determine if a device is generating the string "Enter User ID:". Would 'Match True/False String' prefaced with some type of string trimming be an acceptable method?
jvh
(3,680 Views)
Hi jvh,
the equal function is perfect for comparing string for equality!
Your problem is probably the switch "limit to single line", accessible via right-click of the string control. This will prevent NewLines getting added to the string content... Otherwise make the string controls bigger to show more than one line of text Smiley Wink
(3,671 Views)
OK I looked at your vi.  I have no problem getting the boolean to be True.  Just typr the same text in each string input and "enter" the varible. by one of the following means:
  1. Click the check mark in the toolbar
  2. Depending on your LabVIEW.ini file:
    1. hit <enter>
    2. click anywhere on the FP to remove focus from the string indicator
See the pictures below
"Should be" isn't "Is" -Jay
(3,667 Views)
Thank you both as I learned from both replies. (They came a lot quicker than expected too.)
It would work if I just entered the string and then hit run. The CRLF was definitely the problem. I forgot that the enter keys were different. Well I forgot about the check mark too.
Shoulda got busy right after class but work was too hectic.
BTW, is there a way to trim off carriage returns, etc on strings coming in from a device?
Thanks again,
jh
(3,659 Views)
Accepted by jvh75021
Hi jhv,
there is a function "Trim whitespaces" in the string functions palette...
(3,652 Views)
