String array of time into XY graph
Hi guys
I got a problem i need to solve.
Ive got an array of strings comtaining time and array of numeric(DBL) values
These values i need to plot in an XY graph with time on X-axes and the values on the Y-axes. Any ideeas how to fix this problem.??
a
Message 1 of 8
(4,434 Views)
You can use the Scan From String to get a timestamp (%<%H:%M:%S>T) or relative time (%<%H:%M:%S>t) but since you have repeated times, your graph is going to show different y values for the same x.
Message 2 of 8
(4,430 Views)
Im trying to use the example u sendt me but it aint working
My problem are that i want the string array containing "20:50:27" turned into a DBL value containing "20:50:27" ,that wil say the same value as shown in the string . In the exampl abov only 20 get stored, not :50:27
Message 3 of 8
(4,418 Views)
Take a closer look at the format string you are using versus the one in the Snippet.
Message 4 of 8
(4,415 Views)
Dosent make any diffrent it stil shows 20..Smiley Sad not 20:50:27 in the dbl
Message 5 of 8
(4,412 Views)
Accepted by LCT2
Then go to Graph Properties -> Display Format and set the X-Axis format to Relative Time.
Message 6 of 8
(4,407 Views)
Why did you use "f" in your format string and not "t" or "T"?  That is what Darin is talking about.
Message 7 of 8
(4,402 Views)
It is good information for me. Thanks.Smiley Happy
Message 8 of 8
(4,161 Views)
