String Indicator not updating after each cycle
Hi everyone,
I have a giant file containing many sub VIs. One of the VI contains a program to convert bit arrays into string characters. I placed this VI inside a while loop of the main VI. The sub VI works wonderfully well on the first while loop iteration and the string is  properly displayed on the main VI.
When I change the bit array for the next iteration, the string value does not get updated. I still receive the same string array I obtained in my previous iteration. I tried everything I know: like changing the properties of the string indicator to "Update value while typing" and "Wrap at work breaks" but nothing seems to change.
What could be the issue here? The sub VI is attached.
PS: The main VI contain too many sub VI so it would be an inconvenience to upload all. But I derived the program from here Packet-based Digital Link - NI Community
Looking forward to your replies.
Thank you very much
Message 1 of 11
(2,906 Views)
Can you "save for previous" and reattach. I currently don't have access to LabVIEW 2021. My guess is that you have a race condition.
Message 2 of 11
(2,848 Views)
OK, I am able to look at your VI and the problem seems to be the way you are calling it. Can you show us the caller program? That's where the problem is.
I am not sure why you are playing with the string properties at all. This is an indicator, not a control, so the update mode is irrelevant. The rest are just cosmetic. How is the output of the subVI connected in the main VI? How is the subVI called? How does it get the array?
Message 3 of 11
(2,834 Views)
Which version?
Message 4 of 11
(2,830 Views)
Doesn't matter. I have a computer now that can open it. You need to show us the caller.
("Giant file" already hints at a serious problem, but we don't know how you define "giant". My guess is a dataflow problem or a race condition. Just attach the caller, we don't need all the subVIs.)
Message 5 of 11
(2,826 Views)
So this is the file:
Since there are lot of dependencies, I am only attaching screenshots. I am trying to run the program in USRP which I got from example program here: Packet-based Digital Link - NI Community
I am using the subVI(marked yellow) here:
The previous sub VI is also attached in this reply.
The output of the previous subVI is a bundle containing an array of type int and another array of type bool. The bundle is unbundled and the array of type int is fed to subVI Format Rx Data, which converts it into type string. Let me know if you need any other information
Message 6 of 11
(2,794 Views)
I am not sure why you are attaching another random subVI instead of the caller?
The bug is in what you wrote, not in the VIs from the example.
Can you verify that the global variable connected to the case structure is guaranteed to be true when it is read?
Is "enable?" guaranteed to be true in the input stream cluster?
Message 7 of 11
(2,780 Views)
Yes. I checked the global variable myself through its front panel.
Message 8 of 11
(2,773 Views)
I thought about that as well. I used the example program as it is, without changing anything. I checked the example program with two different strings:
As you can see, the string indicator does not change. It remains same. I verified with higher power, different frequencies as well. I got same results. So the issue is actually with the example program.
Message 9 of 11
(2,762 Views)
Hi @altenbach,
This problem existed even before I added that global variable. That global variable was added to avoid USRP leakage. The global variable is not the problem, I can vouch for that.
Do you think the problem could be that the example program was released in 2011 and I am running it in LV2021 which may be causing some unexpected bug?
Any other reason may be?
Message 10 of 11
(2,658 Views)
