String Conversion
Hello all,
Help needed to solve the issue. Here i attached a vi for your reference.
Message 1 of 10
(5,720 Views)
Yes, number to hexadecimal string
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 2 of 10
(5,719 Views)
No, that will not work:
  • The correct result needs some discontinuities
  • The output string is in hex display
Message 3 of 10
(5,711 Views)
Dear Even. The actual problem with me right now is u can see from the image,
Message 4 of 10
(5,709 Views)
Accepted by Stephen.J
Here is equivalent code that does not use any case structures. I am not sure if it is any simpler. (LabVIEW 8.6)
For a better solution, we need to know what the range of possible input values is, because all you get out is a single useful byte (first byte is always zero). Most likely the code could be further simplified once we have more details on the problem. My currently attached solution gives identical output as your code for all possible I32 inputs (not fully tested).
Message 5 of 10
(5,691 Views)
Dear altenbach,
Thanks for u r reply. the range of input is between 0 - 29 only. The output is communicated with PLC using RS-232 C. the problem which have right now is, if sent the actual input its get changed as ASCII while communicating. I dont have a right person to convert the ascii into required value on the PLC hand.
Message 6 of 10
(5,679 Views)
Hello ,
I am posting the equivalent diagram.
Bijay
Message 7 of 10
(5,668 Views)
That makes little sense: Who changes what into what? Can you elaborate? Usually conversions are done by a computer, not by a person.
Message 8 of 10
(5,651 Views)
Try this:
Message 9 of 10
(5,644 Views)
I this case make sure the input is 16 bits. now the code is slightly simpler (you might need to ensure that the input is not out of range)
Message 10 of 10
(5,632 Views)
