Streaming cluster data on different laptops using webservices
Hello
I am using LabVIEW 2016 version.
My aim is to stream cluster data between two computers on the network.
I have used webservices in my project.  I downloaded webservice example from NI site.
I use JSON script
In development mode, I am able to transfer data from server to client. I can see cluster data getting updated.
But when I build executable, I am unable to transfer data.
I do not get any error display, but the cluster data is blank in the client. I have added webservice in the build properties. I am not getting what I am missing.
Please let me know.
Thanks and Best Regards
Hema
(2,246 Views)
Perhaps it's a firewall issue? Is the executable allowed through?
You can always compile the executable with debugging enabled. Then you can at least look in the executable to see what is happening.
(2,202 Views)
