Strategies for locking down a Waveform Graph or a Waveform Chart???
> However, I believe it is more convenient to use the paint tool on the front panel
Okay, this is really weird: I tried to tell a Color Box to be the "Transparent" color, but instead of being transparent, it simply mimics the behavior of the transparent "icon" in the color tool - it paints itself white, with a "T" in the middle.
Is there a way to tell a Color Box to be transparent? Or is it forbidden for some reason?
[By the way, I was able to get Front Panel "Decorations" to be transparent, but I'd rather use Color Boxes, since they also appear on the Block Diagram.]
Message 11 of 18
(1,277 Views)
I tried using "Editable", and while it does prevent left clicks, it doesn't prevent right clicks [which still gives the end-user the ability to "Autoscale X", "Autoscale Y", etc.]
Message 12 of 18
(1,263 Views)
The attached VI uses a transparent decoration to cover the Waveform Chart.
Message 13 of 18
(1,261 Views)
Transparent object are really a pain when editing a VI. I would suggest a slight modification to your second approach:
Instead of the plain event "Mouse Down", use the filtering event "Mouse Down?" and wire a "True" to the discard terminal.
Voila! All mouse event on the temperature graph are ignored completely. 🙂
Message 14 of 18
(1,362 Views)
Thanks! I think the combination of "Mouse Down?" and "Discard?" was just about exactly what I was looking for.
See the attached VI.
Message 15 of 18
(1,343 Views)
Caroline solution seems to be the most efficient solution, sinec it does exactly what you asked for. Just prevent prevent right clicks by disabling run-time short-cut menus (vi properties>window appearance>customize).
CC
Chilly Charly    (aka CC)
Message 16 of 18
(1,233 Views)
Thanks! That's another excellent approach.
I've attached a sample VI.
Message 17 of 18
(1,225 Views)
You can't turn the "Value" portion of a Color Box transparent, without showing the "T" for the obvious reason that it needs to show you its current color.
Use a Classic boolean and set BG and FG to transparnet instead, if you really want the item to show up on the BD.
Also a comment on the suggestion that you filter the event.
While altenbach is correct that these is "easier" for the programmer, the suggestion leads to a very bad programming practice from a GUI standpoint. The user is allowed to click on something, but is given no indication why the click is ignored. This would be okay if the object were not something a user would normally be able to click on but in this case, the GUI is sending mixed signals to the user. With the transparent object approaches, especially using a decoration, LabVIEW changes the cursor in a way that provides cueing to the user that the action is not valid.
Doug Wilson
Message 18 of 18
(1,312 Views)
