Strange scrollbar behavior
while programming an application I clicked somewhere on the horizontal scrollbar and then the scrollbar was in the middle of the frontpanel.
I have no idea how this happens
Never seen this before!!?!
Anyone has idea how to change this back to normal?
regards timo
(3,597 Views)
Never seen before funny :),Good luck
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,593 Views)
Accepted by topic author TimoSchott
Hi Timo,
Good afternoon and I hope your well today.
I am a little unsure what your issue is exactly, but maybe the following will help.
There are two methods to creating a Horizontal scrollbar,
1) Right-click the scrollbar and select Horizontal Scrollbar >> Always On
2) On the front panel go to Modern>>Containers>>Horizontal Splitter Bar.
I imagine you did number 1.
Now to remove it you have to methods,
1) Right-click the right hand scroll bar (as before) and select >>Always Off.
2) Right-click the created horizontal scrollbar and select Remove with adjoining splitters.
If you cant move the scrollbar to where you want, I would make sure the scrollbar isn't locked. You can check this by selecting the scrollbar, right click and  uncheck Locked.
To achieve the results you have, I firstly created a horizontal splitter. The by selecting the  Right hand side scrollbar in the top pane select Horizontal bar >> Always On.
I hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,562 Views)
