cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Storing of amplitude measurement express data into excel
Hi all,
Need some help with my vi.
1) Attached pic show part of vi that is of concern
2) I need to acquire peak to peak measurement of a signal and stored into an excel
3) 100 peak to peak measurements are required
4)  How can I stop the acquiring of data after 100 peak to peak measurements is recorded?
I am not sure why my appended array is 2D when my results only consists of one row of data.
Any suggestion is welcome and I am still learning about labview.
Descargar todos
0 kudos
Mensaje 1 de 12
3.680 Vistas
This is the correct vi.
Ignore the vi in the first post
0 kudos
Mensaje 2 de 12
3.660 Vistas
Hi riie,
3+4) Use a FOR loop instead of the WHILE loop, set to 100 iterations...
2D array: It's because you create your shift register to store a 2D array. And because of the BuildArray node which is set to create a 2D array. Remove the wire from shift register to BuildArray node and the initialization constant, right-click the BuildArray and set to "concatenate" mode, rewire the shift register...
Mensaje 3 de 12
3.649 Vistas
By following your steps for the 2D array.
The each value is being stored in different column.
However, data is required to be stored in the same column and it works when the shift registered is stored as 2D array
0 kudos
Mensaje 4 de 12
3.647 Vistas
Hi riie,
I don't get this:
Can you please clarify why data is required to store in same column and in the same time you want to use more than one column? And why do you wonder why your data is stored as 2D array?
I really don't get this...
0 kudos
Mensaje 5 de 12
3.645 Vistas
Hi GerdW,
(Edited) Thanks your method work, and transpose must be set to true for data to be written in the same column.
Next is the program will be run again and the 2nd set of 100 data will be stored in the 2nd column, etc.
Amendation have to be made to achieve this and any guide to how this can be done?
eg.
1st set              2nd set
1                       1
2                       2
(100 values)    (100 values)
0 kudos
Mensaje 6 de 12
3.643 Vistas
Hi riie,
writing in an additional column in a spreadsheet file is not possible by simple means. In the end you have to load the full file into memory, append the new column and write back into a spreadsheet file...
0 kudos
Mensaje 7 de 12
3.624 Vistas
Thanks! That is what I read from other thread earlier on, this prove to be problematic.
Anyways to work around it? Other than using the paid Report Generation Toolkit
0 kudos
Mensaje 8 de 12
3.620 Vistas
Hi riie,
RGT might be an option.
Using the approach (read file, append column, write file) might be cheaper...
0 kudos
Mensaje 9 de 12
3.617 Vistas
So the only free method is using your approach?
Thanks!
0 kudos
Mensaje 10 de 12
3.614 Vistas
